I'm new to DVD..When DVDWS2 writes the .iso file in the finish step, is it in the UDF 1.02 format or ISO, or UDF/ISO?
Next, is it better (in terms of a higher rate of compatibility) to burn the .iso or the DVD folders themselves to the disc? And in Nero, do I need to specify UDF if I'm burning the folders? Basically, on this one, I'm confused as to when you specify UDF, ISO or UDF/ISO...
One more, is there a 2GB limit for the ISO format? I tried to use the ISO/UDF in nero and it says because it's over 2gb, that I have to use UDF....please advise
Results 1 to 1 of 1
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 18:01 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
