Hey all,
What is the difference between the 2? I have a dvd-rom here in my laptop... that will ONLY play DVDs i have burned from a "full backup" of an original DVD. It will NOT play a DVD i burned from a "reauthor" which is JUST the movie, no menus, no extras ect. I use DVD Shrink to re-encode the movies to a suitable size.
Can someone tell me why my dvd-rom will play one flawlessly, but not the other? Its a brand new drive, i am using windows media player 9 and/or Power DVD to try and view.
When i put the reauthored dvd in (the one without menus or extras), it just spins and spins and tries to read it... then if i try and view it from windows explorer it says "this disk cannot be read by windows, it may be damaged or in a format that windows does not recognise". and if i try to open it in PowerDVD it says that the DVD-Rom drive is empty.
Now if i do the exact same thing with a "full backup" dvd (which includes all the menus, extras ect), it will autoplay, play in windows media player, i can browse it in windows explorer, and i can play it in power DVD.
I use the same program (dvd shrink) to fit them to a single DVD+R, I am using the SAME media (memorex DVD+R's), i am using the same burning software (Nero 6.3 ultra) and the same ROM to try and read them
Is there a certain codec i need to play the "re authored" dvds i make? I am completely baffled as to why it will play one DVD+R which is a full backup, and not the other DVD+R which is a re-author without the menus.
Syndrome
Results 1 to 14 of 14
no body has any ideas? damnit
this is the whole reason i bought the dvd-rom, to watch DVDs!
Syn -
That IS a wierd situation. I have a DVDRom drive that will not play self made DAO(Disc At Once) CD-R's so I guess nothing is impossible. Have you tried authoring one with a menu in TMPGEnc DVD Author? It is a 30 trial and is fairly easy to use AND there are several easy-to-follow guides on it. Maybe your DVDRom needs a menu for some reason....TMPGEnc DVD Author will give you one.Originally Posted by Syndrome
yeah you are right. my DVD-ROM(s). will only play dvds with menus. is this standard? I cannot get EITHER of my dvd-roms to play ANY dvd movies WITHOUT menus... am i missing a codec or something?
Syndrome -
Syndrome, what DVD Shrink version are you using?
was using 3.15, now using 3.16... both have the same result
dvd-player has no problem with them
but DVD-roms wont recognise them... (the ones with no menus)
syndrome -
I'm affraid I don't know why this would be.
I can only suggest you try the latest beta: v3.1.7b5. -
well its not only dvdshrink ive tried.
Ive tried using tmpgencoder, and tmpg dvd-author aswell. When i burn a dvd WITH menus, it plays fine in the dvd-roms.
but even with tmpg encoding, when i burn a dvd WITHOUT menus, it still wont play it.. says drive is empty
could it be a windows problem? im using winXP pro.
Syndrome -
I'll give this a shot.
When using DVD Shrink, in the options, change the region code to 1, assuming your in the U.S. or Canada.
In other words, don't remove the RCE protection, but manually select region 1. -
Syndrome
if you reauthor try to make sure the filesize is at least 4.0G. i have had issues where dvdrs that are less than 4.0G are not recognized by the player (ie Disney movies). use a dvdrw to experiment. good luck. -
yep all of my dvds are between 4.3 gig and 4.4 gig.
man this is driving me nutz
BIG EDIT: I just burned a DVD+RW with region 1 coding (not region free) without menus, and its playing!!
now is there any way i can tell my computer to read region free dvds?
Syndrome -
That is too wierd. Thats....backwards isn't it?....not being able to read a region free disc? If you were trying to play a region 2 disc in your region 1 DVDRom I could understand it not playing it....you learn something new everyday.
Finally got around to doing a full backup - how often do you do yours?
By yoda313 in forum Off topicReplies: 6Last Post: 1st Feb 2012, 00:10 -
BD Rebuilder Full Backup without trailer
By jonlar in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2011, 15:46 -
BD Rebuilder FULL backup
By jedisinclair in forum Blu-ray RippingReplies: 1Last Post: 14th May 2010, 21:00 -
DVD Reauthor- Button highlight in Merged DVD
By src2206 in forum DVD RippingReplies: 0Last Post: 4th Aug 2009, 00:37 -
Full Backup Mode in BD Rebuilder
By fjmr in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jul 2009, 04:32
