I have Nero 6.3.0.3 and I've had this problem for about the last two versions. Nero itself will load fine, but when I'd go to load the first MP3 into an Audio compilation, a command prompt window will open up with just a blinking cursor. I press the 'Windows' key on my keyboard so I can go back to my desktop. I've checked the path of the command prompt window and it points to 'C:\Program Files\Common Files\Ahead\AudioPlugins\RMADEC.EXE'
Anyone know what that is? I know its not a virus or anything, but it get annoying when it pops up every time I make an Audio CD or go into Nero Express. Everything still works perfect if I close out of that command prompt window. Any ideas? Thanks.
Results 1 to 1 of 1
Audio Fade in/out plugin for VirtualDub
By aaxpers in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2012, 14:00 -
Nero 6 audio editing question
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2009, 00:53 -
Nero Blu-Ray/HD plugin problems
By lostinlodos in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 20:01 -
Where can I find Nero Showtime plugin for ATI Remote Wonder?
By fk in forum Software PlayingReplies: 0Last Post: 13th Jul 2007, 03:53 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
