Results 1 to 9 of 9
    Mar 2003
    Sweden/Norway
    I have Sony trv-890e and Win2000.
    It has (hacked) enabled DV-IN and DV-OUT.
    When I try to connect the camera to my PC, the computer stops responding. (mouse pointer won't move)... and when I disconnect the dv-cable, the computer starts responding again.
    Strang..
    Is there a faulty DV driver ??
  2. 1) Win2000 or Win2000 Pro?
    2) What Service Pack, if any, are you running?
    Mar 2003
    Sweden/Norway
    Sorry.
    Win2000 Pro
    Service Pack 4.
    Funny think is that the camera has worked before.. but now it then to work at 1 out of 10.
    It's called a "firewire" cable, not a DV cable. Now that you know what it is, look in the MS KB.
    Mar 2003
    Sweden/Norway
    Okey, DV=firewire.
    But then, what is "MS KB" ?
    (microsoft KiloByte)
    Is there a driver to download for the Firewire card ? (it came with the pinnacle box)
  6. Mod Neophyte redwudz's Avatar
    USA
    Microsoft Knowledge Base on the MS site. If you use AVIcodec, check for 'dvsd DV video for windows driver' , it's the MS DV driver. You don't need any other driver for DV transfers, it should be included with the OS. May have a bad cable or some other problem.
    Mar 2003
    Sweden/Norway
    Thanx.. I will check this software out.
    Did not find any drivers on MS page.. only some drivers for panasonic cameras and XP..
    Well, thanx for helping!
    I guess a new installation might work instead..
    Jun 2005
    Romania
    Hello!
    I have almost the same problem.
    I was using the handycam Sony TRV265E on winxp sp1 and work'it.
    Recently, I try to copy to handy one movie which are capturing and editing with Windows Movie Maker (about 1 min.) but, because after 20 min. was not finished, I close with task manager Windows Movie Maker. After that, my system not recognise handycam. I try win2000 sp3, and install a clean winxp sp1 without succes.
    When i connect i-link cable DVin apear on LCD at handycam.
    If anyone know a solution, please help.
    Thanks.
    P.S. Sorry for my engleash.
    Feb 2004
    Australia
    If the camera you are using only has usb capabilities , remove all other usb devices prior to connecting camera and recording from it .
    This is a well known problem with sony units , and this warning is a small piece of print in the middle of the manuals .
    Some users may be experiencing the blue memmory dump warning screen from xp , this is what is causing the problem , and the camera is to be the only usb device connected while capture and editing is being performed .
    Camera should always be powered on and in usb streaming mode prior to connecting to pc .
    For those wanting to avoid the problem , and unit supports firewire , use this instead .
    The other way is to output to vcr , then the vcr output is connected to capture card on pc .
    For under $80 , you avoid usb and firewire issues , which may be harmfull to your pc in the long run .
    Start capture om pc , start dv playback , stop camera at end , stop capture , edit for dvd if required .
    Also handy for those wanting copies on vhs tape , cause they dont have a pc ...
