I need some help with VirtualDub. Does anyone know how to apply a filter between one frame to another, meaning start and end points.
I am trying to remove subtitles from a video that are in a forgien language and apply my own in english. I am using the "logoaway" filter (logoaway v4.0 Beta 3) plugin for VirtualDub to do this. The filter works great and to my satisfaction, however I only need it for a very small portion of my video in the middle, I don't want this filter apllied to the entire film, otherwise I have this blur that shows up from start to finish.
Anyone know how to use any filter, or this filter just for the portion of video you want?
Thanks, Mike.
If the unconditional filer works as stated it could indeed be the way to go.
If've done this in th past by seperating the video (direct stream copy) then running the filter on the desired segment then appending the segments togeather (the only portion of the film i have to reencode is that to which i apply the filter.) -
Many Thanks MGH.
That filter worked perfectly, thanks again.
Mike.
P.S. Thanks to all the people who posted for your help.
VirtualDub Video Compression h264 encoder Not Shown
By darkw1zard in forum EditingReplies: 2Last Post: 18th Oct 2011, 14:28 -
VirtualDub filter to insert video from another source into a corner?
By Riothamus in forum EditingReplies: 2Last Post: 6th Jun 2011, 07:51 -
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 08:24 -
How to apply a filter to just a part of the movie with VirtualDub
By Drakul in forum EditingReplies: 5Last Post: 19th Sep 2008, 17:08 -
Filter just part of a file with AviSynth?
By Holonet in forum EditingReplies: 6Last Post: 2nd Aug 2007, 06:21
