I accidently pulled the plug on the computer while it was on. When I turned it back on it said the computer will shut down in a few seconds and shuts down right away without loading the OS. Does anyone know what the problem is and how I can fix it?
Approximately how long into the boot process does this happen? Before any Windows loading at all? After drives check?
Also what was the PC doing when you accidentally pulled the plug out? -
Try to boot to safe mode.
Press and hold F5, F8 or something like that. Depending on your Operationg system.
If that doesn't work try this:
Unplug it from AC power
Remove the CMOS battery,
Count to 38,
Put battery back in,
Connect AC power cord
Reboot...
What does it do now?? -
I fixed it... I just reformatted... I think it was a corrupt file(s). Thanks for your help.
Computer shuts down
By shaolin2006 in forum ComputerReplies: 16Last Post: 18th Nov 2011, 23:15 -
Convert program shuts off computer
By Crescere in forum Video ConversionReplies: 7Last Post: 12th Aug 2011, 14:54 -
Computer shuts off using DVD Shrink
By paulnsf in forum Newbie / General discussionsReplies: 7Last Post: 12th Apr 2009, 12:14 -
By paulnsf in forum Newbie / General discussionsReplies: 0Last Post: 8th Apr 2009, 03:23 -
Computer Shuts Down For No Reason
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 23rd Nov 2008, 16:33
