I am tryinig to figure out how to print on business card CD-R media using the Epson printing software and I can't find a template to use. Does anyone have any suggestions or know of software (hopefully cheap or free) to do the job? TIA![]()
I'd rather have a bottle in front of me than a frontal lobotomy.
File / Inner / Outer Diameter settings...
Switch to 8 m/m disks or use options and set your own size...Not bothered by small problems...
Spend a night alone with a mosquito -
The 8 cm setting assumes a round disc and ends up inking a round shape instead of a rectangle shape. I now have a cd tray with ink on it! I e-mailed Epson and hopefully they have a solution or this printer is getting returned!
I'd rather have a bottle in front of me than a frontal lobotomy. -
Let us know what happens.
I was about to order the business card cd's myself, but will wait now.All good things come to an end......
that's why they call it a "climax". :) -
This is going to sound harsh, but here goes...Originally Posted by YngwieJM
Clean the tray with glass cleaner or wash with soap and water, and don't print shapes that are not the same size as the media you are printing onto. Is that so hard? Common sense says don't print a large circle onto a smaller rectangle.
Or if for some reason you can't avoid making large circles, put a thin sheet of paper under the business card that is the same size as a full 12cm disk.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
That wasn't so harsh. The thing is that the 8 cm ring that goes in the cd tray is shaped like a business card cd-r and I read online that it can print the shape. I tried using Nero cd label maker and it will only work with labels and not direct to disc printing. Did Epson drop the ball on this one? I think they did. Should I have to rig up a piece of paper under my cd-r to make a $400 printer do what I was told it could do?
You could always make the rectangular artwork in a photo editor, and then bring it into the printCD software. I don't think Avery has a proper template for those cd's either. It is a whole market segment that most companies don't acknowledge.
Another thought, if you make a cardboard filler around the CD, you could make your artwork so that it over prints. Then you will never have any edges showing, but just a thought.
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
bfg tech leaving graphics card business
By deadrats in forum ComputerReplies: 6Last Post: 23rd May 2010, 13:51 -
Would you name your own business after yourself?
By yoda313 in forum PollsReplies: 16Last Post: 25th May 2009, 20:57 -
Where to buy business card DVD-R?
By stantheman1976 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2008, 13:36 -
HP D5300 - business card CDs?
By mrtunes in forum MediaReplies: 5Last Post: 9th Aug 2008, 20:53
