Greetings Group
I've got a series of MPG files that want to join into one continuous movie. I believe I've seen a utility that will do this for me as each file is named thus:
MovieFile.MPG.001
MovieFile.MPG.002
MovieFile.MPG.003
MovieFile.MPG.099
Can you point me in the right direction please.
Thank you.
Spoog
Results 1 to 11 of 11
There could be a utility that just joins MPEG files, but I would use Tmpgenc. The MPEG Tools menu option brings up a tool that joins, splits, multiplexes and demultiplexes MPEG files. Works fine everytime.
The more I learn, the more I come to realize how little it is I know. -
For Joining files, MPG included, I use a freeware program called Filemerger. Works for most any file. Fast and easy. Can join MPG or AVI or others, even if there are hundreds of parts. You can get it here http://home.planet.nl/~doesw008/filemerger.html or other places. Google can find it also.
Joining MPGs is always a tricky business - I've never succeded 100%. It's always audio sync probs. But why'd you want the mpgs merged into one? I mean - depending on your end product, you might be able to go there without merging them...
/Mats -
PLEASE don't hijack topics
"We were in barstow on the edge of the desert when the drugs began to take hold." -
I have the same problem, used Lordsmurfs project on restoring DVD (demuxing back to m2v), I now have one audio wav file and two m2v files. Need to join the m2v's together so I can re author them.
Sorry about hijacking this message but it seems that we have the same problem.....if any programs are suitable can they join the m2v as well as mpg's???Hmmm, time to kick ass and chew bubble gum....But am all outa gum. -
Guys what he has there is Hjsplit files.
Spoogle you need a tool called Hjslpit/joiner, do a search in google for it it's free.
Once you got it, just use the join function on the first file and the porgramme will join all the files together.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
Do you have to re name the files to 001 though first??
Brany Lads BLJoin.
Will take the .001-.############ files and output the correct file.
You could/will still have problems. Most idoits, I mean people, don't cut the mpeg correctly so you end up with PTS errors.
The best/correct way to do this is, rename all of your files to just
MovieFile.MPG
MovieFile.MPG
MovieFile.MPG
MovieFile.MPG
Run Womble's MPGVCR's GOP fixer on each file, then join with Womble, TMPG, or whatever. Don't forget to bitch the person out that posted the file that way, and point them to winrar's web site, so they can properly split up a large file into smaller chunks without destroying the content.
If you attempt to join before correcting the header your playback will have problems. Usually stopping at the time which the first would end, not seeking.................
Hard disk utility to show most-recently updated files?
By Ai Haibara in forum ComputerReplies: 0Last Post: 12th Sep 2010, 22:45 -
Joining mpg files from VOB2MPGPRO
By Mudmover in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 2nd Jun 2009, 07:06 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32 -
joining up .mpg movies
By natty in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2008, 06:14 -
mpg joining?
By jay_lubb in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 11:02
