I have got a file with these different files on it:-
CUE
SHN
SKT
MD5
Can anyone tell me how i can burn this file on to disc or what i even do with thes files????
I don't come on this site very often so can you please send your reply to Live2Skate101@hotmail.com please![]()
Results 1 to 10 of 10
Originally Posted by quiffboy123
Someone didn't do their homework
Doubtful man. Part of this being a forum is that people reply by posting, not my e-mail, but you may get lucky and some kind soul will help.I don't come on this site very often so can you please send your reply to Live2Skate101@hotmail.com please
He's got a Hotmail address also, a real sign of a stable individual with ties to the community
Sorry, quiffboy123, I couldn't resist. My best advice is to do a search on, say, GOOGLE for those terms.
don't worry i found that quite ammusin next time i won't though and i only put my adress in coz i thought someone would be kind enough to tell me what to do with these files but obviously you's lot are no help to me at all
And Tgpo i've tried burning the cue file and it doesn't work so can u help me out at all???
I can if you are on a mac, otherwise It's out of my knowledge.Originally Posted by quiffboy123
Isn't a SHN file for audio? I used to get a lot of legal live recordings (DMB, Dead, Phish, WSP, etc.) off of FurtherNet and they had a lot of stuff in SHN formats I believe.
Not always illegal, you know, but I see why he got the reaction he did. -
The .BIN / .CUE CD image format was made popular by the CDRWin software. Afterwards many programs have started supporting or partially supporting it, including: Nero, BlindWrite, CloneCD, FireBurner, vcdimager and cdrdao. The .CUE file contains VCD or SVCD or other data track layout information.Originally Posted by quiffboy123
SHN is a file format. SHN is short for "shorten". SHN files are compressed ("shortened") WAV files. SHN uses a lossless compression method.SHN
A .skt file is Shorten seek data.SKT
Shorten seek data can either be embedded inside a Shorten file, or "live" outside the Shorten file. A .skt file is seek data that happens to "live" outside the Shorten file.
The reason for a separate seek data file is because the original seeder did not encode that particular show with Shorten v3. Re encoding the old Shorten file with the seek data embedded into it would change the MD5 checksum, and cause much confusion. Because of this, you should never append seek data to older Shorten files. You can create .skt files for your older (non seeking) Shorten files with SHN v3 tools.
.skt files are only necessary if you want to listen to Shorten files in ShnAmp or XMMS-SHN and be able to seek. Seeders that encode new shows with the SHN v3 tools will have seek data automatically embedded into the SHN file by default. The seek data is there so people can take advantage of seeking without needing additional (.skt) files
Plain text files with checksum information for the shns. The checksum strings inside are like 32-character ID numbers for each shn, used to check the integrity of the shns and to "fingerprint" them. People create md5s at the same time they create the shns. The files are typically named by band abbrev, show date, and often disc, such as ph2000-04-20d1.md5. Within the md5 file there should be a separate line for each shn.MD5 -
TGPO-
I am either very impressed by your actual knowledge or by your superb ability to seach the web.
It's all about google baby.
You'd think more people would use it
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
