I have transfer some Mpeg 2 video which was recorded on a Ram disc in a Panasonic DVD recorder. I used Mpeg2VCR.
The problem I can't now use the Mpeg 2 file as something is wrong? It plays fine with Power DVD but TMPGenc says the file is not surported?
The file info is
File : 166 Mb (360 Mb), duration 0:05:08, type MPG, 1 audio stream(s), quality 72 %
Video : 350 Mb, 9556 Kbps, 25.0 fps, res. 352*288 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 9.40 Mb, 256 Kbps, 48000 Hz, 2 chan., 0x2000 = AC3 DVM [0x80], Supported
The size is the same as VCD for some reason? Is there some other way to convert this file so I can make a DVD?
TMPGENC DVD Author
dont use the dvd video file import, but the other one (cant remember the name of it right now). change the file type to all and your .vro will show up.
I have done a lot of them this way. If you have issues, look for a user by the name of donpedro. He has a lot of info on panny recorders and their trials and tribulations. -
Just import it in your dvd authoring tool. You don't have to convert it with tmpgenc...or are you talking about tmpgenc dvd author??
I do have TMPGenc DVD Author and Ulead DVD Movie Factory but when I test the video in the program it only shows a part of the screen?
Power DVD will play the file properly but WMP or the players in the above programs wont?
I need to clear some space and then I will try a DVD-RW to see if it plays ok
Thanks for the help -
No - It was recorded in SP 2 hour mode thats the funny thing?
When I have done 2 hour mode before the files have been 704 x something?
I have not done a test burn and it plays fine?
Strange but as long as it works?
Should I change any other settings on the DVD recorder?
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 12:50 -
Converting DVD-VR (DVD-RAM) with Multiple Tracks
By alexs77 in forum DVD RippingReplies: 2Last Post: 26th Dec 2009, 04:27 -
HOW to DVD-RAM on PC so that it plays in my PANA DVD Player
By saxon22 in forum Authoring (DVD)Replies: 21Last Post: 18th May 2009, 08:34 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 20:55 -
DVD-RAM from Panasonic ASTC recorder to PC for DVD authoring?
By Philbiker in forum Capturing and VCRReplies: 2Last Post: 30th Oct 2007, 18:42
