Experimenting with creating motion menus using DVD-Lab and Pinnacle 8.xx.
Using Pinnacle, I first edit and combine a few clips from movie captured off TV with ATI 9000 Pro card. I save that edited clip as MPEG2 file and import into DVD-Lab. Problem is, the movie is letterbox format, which is not desirable for the motion menu.
I can't find anywhere in Pinnacle, or in its manual, where you can convert letterbox to 4:3 fullscreen. The only way I've found around this is to import the menu clip into TMPGEnc Source Creator and use the crop feature, spreading the picture out until the black is gone. This creates a few artifacts, however and seems a bit "unsophisticated."
Is there a better way to do this? Thanks.
Why dont you encode the clip at 4:3 and add borders instead of going full screen?
Borders are the black stripes,you`ll get artifacts when going to full screen anyways from letterbox,try raising the bitrate for the fullscreen encode,might help.
How to convert videos and resize them to make them fullscreen
By zikegi in forum Video ConversionReplies: 3Last Post: 3rd Nov 2011, 11:55 -
White letterbox bars on menu in DVDLab Pro
By FaterCarras in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2010, 03:19 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 16th Jul 2009, 23:01 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 11:55 -
iPOD Video: How to convert widescreen to fullscreen?
By maxim730 in forum DVD RippingReplies: 4Last Post: 5th Jun 2007, 09:07
