I have a pentium 3 HP computer with 320 megs of RAM & an Avertv Stereo card. I've been in the process of capturing various clips from VHS tapes, all in various degrees of age, tape speed, & original sources. All capturing done in Mpeg2 realtime with MGI Videowave. All clips so far have been good except for one clip in particular. The tape plays fine but the capture itself has some weird things going on which i've never seen before. The file plays OK for the first 10 seconds or so, then the video will be in slow motion for about 2 to 3 seconds, no change in the audio ,however, causing major sync issues. then a few seconds later the video will speed up then both audio & video are back in sync until a few seconds later the whole process is repeated throughout the rest of the clip.
The capture had no frames dropped, but I can't preview the file duriong capture, so I can't tell what's going on there. other clips from the same tape have captured fine. The VCR i'm using is a JVC if that helps.
I tried re-encoding the file but the same issues are present in the re-encoded file. De-multiplexing had no effect either.
It sounds like the tape has some damage at the edge. That's where the timing info is recorded. If you can get access to a TBC try that to clean it up.
If you can't use TBC, you have to capture this video analogue, filter it the old traditional way (Virtualdub) and then encode it to mpeg 2
XBOX 360 Capture Card (warning, weird setup xD)
By erickek in forum Capturing and VCRReplies: 1Last Post: 6th Jan 2012, 14:36 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 10:17 -
Capture Settings / Weird lines in final product
By BooBerry in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 26th Jan 2009, 12:14
