I'm trying to find a guide that will help me convert this TS file to a file so I can make a DVD out of it. If anyone has any suggestion I would appreciate it. I checked the site and can not find to much info on this.
Thank's
Results 1 to 10 of 10
This isn't as easy a process as it should be. Take a look at http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=351180 and see what you think. This is for 480p content from FOX, so you have to add a scaling step in there for 720p or 1080i content. I'll probably post a guide for that type of conversion in a few weeks. But take a look and let me know if you have any questions.
Xesdeeni -
I've never tried it, but I believe Womble MPEG2 VCR can open a transport stream and save as mpeg.
Thank's all for the help. I think I just might wait for your guide. I went to the link and just got more confused lol. I will keep and eye on the guide section . As for mpeg vcr I will give it a try. Thank's again
Well I used the mpeg-vcr program and I was able to make a Mpeg file but it does not play right so I'm guessing there is something else I'm missing. Plus when I go to that drive and click on that file I get booted back the the desktop. So I guess I will wait for a guide.
Moonlight Cordless Ltd XMuxer v.2.03 works perfect for this --- so does BBDMUX.exe
manzinita also have a real good app for this ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Well I tried Moonlight Cordless Ltd XMuxer v.2.03 but can't seem to get it to work. I read the directions but when I hit start it does nothing. Is there a guide for this program out there? Thank's allot for the help
didn't read the user guide ?
here it is in part:
HOW TO USE XMUXER
1) Go to the Start menu, Programs, Moonlight Cordless, Xmuxer (program group), Xmuxer (the program itself).
2) You see the Evaluation version dialogue.
- Press the OK button and you’ll see the main interface of the program (if you want to download the latest version of the program or look for some additional information press the button with our URL on it).
- In the dialogue window there are 3 buttons illustrating the main functions of the program – Remuxer, Demuxer, Muxer. (Figure 1.)
3) Choose the function you need by pressing the button with a proper title.
Figure 1.
REMUXER
Remuxer – the function providing demultiplexing of MPEG2 (Program or Transport) stream, followed by multiplexing of one of the VES (Video Elementary Stream) and one of the AES (Audio Elementary Stream) into the standard MPEG2 movie. (Figure 2.)
You see the Remuxer dialogue where you should press the Open file button and choose the file you’d like to remultiplex.
To save the results of remultiplexing press Save file and enter the filename in “Save file” dialogue.
Having chosen source and destination file you may press the Prepare button.
If the operation succeeds you see the list of audio streams in Audio output list box and the list of video streams in Video output list box or error message box in the case of fail.
Press the Start button. If everything is ok you see the process status display changing.
When operation is over, the “Process complete” dialogue appears.
The results of remultiplexing you can find in the catalogue you have chosen before.
Figure 2.
DEMUXER
Demuxer—the function providing demultiplexing of MPEG2 stream into VES and AES and their saving as files. (Figure 3.)
You see the Demuxer dialogue where you should press the Open file button and choose the file you’d like to demultiplex.
Click the Prepare button .
If everything is ok you see the list with outpins statistics where both VES and AES of the stream (MPEG2 (Transport stream, Program stream),MPEG1 (System stream) compatible) are shown or error message box in the case of fail.
The program also offers you to save the results of demultiplexing. In a window with outpins statistics click the streams you’d like to save one by one, or you can do a double click to specify the catalogue where you’d like to save them.
Click the Start button and the process of demultiplexing will be performed, and the streams you have chosen will be saved as files.
The results of demultiplexing you can find in the catalogue you have chosen before.
Figure 3.
MUXER
Muxer – the function providing one VES and one AES multiplexing into one MPEG2 Program stream. (Figure 4)
You see the Muxer dialogue where you should click Open file and choose the audio stream file you’d like to multiplex and then video stream file.
Click the Save file button to choose the catalogue where you’d like to save the results of multiplexing.
Click the Prepare button to make the Start button available.
Click Start.
When process of multiplexing is over, the dialogue “Process complete” appears.
Figure 4.
NOTE: If we switch Remuxer and Demuxer to PVA standard, it will be compatible with input PVA standard movies.
Now Muxer and Remuxer are compatible with streams included AC3Audio."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I already read the directions 20 times and like I said It does not work. Where it says Time Elapsed it goes to 6 and thats it. So I'm not sure whats wrong. Thank's for the reply I will keep at it until I figure it out or just forget about it but I hate to give up. Thank's again
works fine for me -- but if you are having problems .. use BBDMUX instead (it is in BBTOOLS package)
i work with transport streams daily for HD"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
HD mpeg2 transport stream re-quantization?
By live4ever in forum DVB / IPTVReplies: 2Last Post: 21st Jul 2009, 19:25 -
MPEG2 transport stream software
By PCNG in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 14:10 -
Re-encoding MPEG2 Transport Stream (.ts) file
By kary.sharma in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 04:01 -
MPEG2 Transport stream HD 1920x1080i specs Help
By stealthProd in forum Video ConversionReplies: 22Last Post: 13th Sep 2008, 01:59 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
