Drive = NEC1300a
Problem = Disks write OK. Work OK for a week or so. Then start to lose/corrupt data!
I've burnt around 20 DVDs, various makes, +R & -R, and the write process completes without errors. The DVD will work fine on NEC and other drives for a while, and then I find the movie will stop or I cannot read the data (cyclic redundancy check error) that was originally fine.
I'm begining to think the NEC1300 drive is faulty.
Any ideas anyone?
Well, im just guessing but i think u're using cheap media and burn at 4x right? That happends do me too, thats why burn at 2X only to that kind of media and after i do a "verify written data". Not a burner issue, its a media problem.
I hope i could help ( sorry 4 my english) -
Main types used so far are Bulkpaq and Zero Defex (Ricoh). Plus a couple of unbranded disks that came with the drive.
Here's the info for the media types.
Bulkpaq
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID TDKG010000d9
Format Capacity 3.79GB(4.07GB)
Book Type DVD-R
Media Type DVD-R
Media Id Code Speed 1.0x 1385KBps
Available Write Descriptor CLV 2.0x 2770KBps
Write Strategy Speed 1.0x 1385KBps
Data area starting sector 30000h
Data area end sector 1E52BFh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
ZERO DEFEX
Media Information
Media code/Manufacturer ID RICOHJPNR01
Format Capacity 3.95GB(4.24GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area end sector 1F99BFh
Number of Layers 1
Problem with recently burnt DVDs not reading suddenly in any player
By Xmetalfanx in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Jul 2011, 22:27 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
Vista burnt dvds fail standalone playback
By bornmild in forum DVD RippingReplies: 3Last Post: 22nd Feb 2009, 17:02 -
reducing data loss from scratches
By Chipp in forum Authoring (DVD)Replies: 4Last Post: 17th May 2008, 17:38 -
fat32 to ntsc without data loss
By lordhutt in forum ComputerReplies: 11Last Post: 26th Jan 2008, 19:36
