I am trying to decide if I should keep some RAM I just bought, so I tryed a little experiment.
TMPGENC settings were, Highest quality motion search, constant quality 8000 max bit rate, 704x480.
Converted a 1hour, 35 minute video.
With 512 M of PC 4000 ram, running at DDR520, took 10 hrs, 50 mins.
With 256 M of PC 2700 Ram, running at DDR350, took 11hrs, 20 mins.
That's only around 5% difference in speed, using 1/2 the amount of slower RAM.![]()
One other difference, with 256, FSB speed was 265, with 512 it was 260.
Randy
As expected. Encoding is almost 100% depending on processor speed.
/Mats -
Yep, it's nearly 100% processor based. The true difference you experienced is actually just plain old XP. You need a minimum of 512 MB to do anything useful. It will run with 256 MB, but really 512 is much better.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
on my old xp1700 256mb ram i stuck an extra 512mb ram in barely noticed the difference
when i got my new xp2600pc 512mbram it appears to do video editing tasks a fair bit quicker i think the new xvid codec has something to do with it also(in my case) -
Originally Posted by Gazorgan
BTW, I have seen people recommend buying 1g of ram for heavy video rendering. Glad I did not go that route.
Randy -
I have 512 MB or RAM at home (W2K, less of a RAM hog) and I routinely run out of RAM. It's not from encoding, it's from doing other things. 256 would definately bog down a LOT!!! For an 'average' user they can get buy on 256 Mb, just don't have 3 torrents open, be editing video, and 3 webpages up....
1 GB is probably overkill for 99.9% of users. The remaining 0.1% know what they are doing and have the 1 or 2 GB :PTo Be, Or, Not To Be, That, Is The Gazorgan Plan
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 10:12 -
Question about Lynksys NAS200 and moving large amount of data to it.
By nzdreamer55 in forum ComputerReplies: 0Last Post: 9th Sep 2010, 09:09 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Adjusting amount of light
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jan 2009, 18:07 -
What is the smallest amount of change in color that the eye can detect ?
By Movie-Maker in forum Newbie / General discussionsReplies: 8Last Post: 6th Dec 2008, 10:41
