Is there a program that I can use to convert mpeg or avi files to the dv video format. I have a LiteOn 5001 standalone dvd recorder that has a dv firewire input. I would like to take the converted dv files and transfer them to the LiteOn to author/burn.
Will this even work?
Thanks in advance,
Jason.
The firewire is only an interface to communicate with the burner. Having it in DV format is a moot point.
Do you intend to play your files in a DVD player? If yes, you will need to author the DVD into the correct structure and burn it using the correct tools.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
No. It's not a burner. It's a DVD video recorder. Just like a VCR, except it uses DVD's. Maybe I wasn't clear enough.
Thanks,
Jason. -
Jason,
I did a little digging and it turns out that the Liteon 5001's DV input only accepts DV AVI files from a camcorder. I guess you'll have to transfer the video file from your PC to the Liteon the analog way.
Regards,
Gil. -
You could always encode to a very high bitrate MPEG-2 and output via a Sigma Designs Xcard.
This will output MPEG-2 with very good quality because the card has all the same stuff as a stand alone DVD player.
In short the output is better than that of ANY video card output but the trick is it only supports MPEG-2 (it also supports DivX but not very well so I wouldn't count on that).
So you could encode everything at CBR 8000kbps MPEG-2 standard with LPCM audio then output through the Xcard to your stand alone DVD recorder. In fact I think the Xcard can handle even higher bitrates than that ... me thinks it can handle combined audio and video up to 15000kbps!
But if you are going to go through all that then you might as well just get a DVD burner. You can get 8x dual format models now for around $100
Hate to say it but Windows Movie Maker2 will allow you to import an mpeg file and then save it back to a digital camera. This tape can then played to your LiteON. Should work very well and have no loss as the Mpeg will be converted to AVI.
Try with a short film and let us know how you get on !! -
I recommend DropDV. On Mac OS X, just drop your MPEG file onto DropDV and it creates a DV stream.
http://www.dropdv.com
Video/audio TS files convert to an uploadable MPEG video
By Prizm007 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 15:30 -
How to convert Mov video files to Mpeg
By Tintin11 in forum Video ConversionReplies: 4Last Post: 8th Dec 2010, 09:14 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00 -
how do I convert Mpeg 4 video
By gatefan810 in forum Video ConversionReplies: 9Last Post: 24th Jun 2007, 17:01
