For some strange reasons all the avi files that I saved (8 months ago) in one particular data hard-disk "F" could no longer be accessed. Error message says file could not be open its either in use or protected, or disk is full etc. None of which is true as far as I can see. There are no other programs running. Similar message when trying to virus scan these files, the file cannot be accessed.
There are no problems accessing the avi video files on the other 3 hard disks ; System Disk "C", and disk "D" and "E".
I'm desperate to recover these raw video footages as the original tapes are no longer available. Grateful for any help I can get.
Can you copy it to another drive or partition, or will it not let you access it at all? Perhaps your drive is failing?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
These avi files could not be copied as they are not accessible. However I could copy avi file from a different drive to this 'F' drive and it then could be accessed and played wihtout any problem, this seem to indicate the hard-drive is still healthy.
You could boot into Safe Mode with Command Prompt (you're using WindowsXP I assume) and try copying or moving the files to a different drive from the command line. I've read that deleting the following registry entry may also solve the problem after a reboot:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D9 4-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32.
That registry entry has to do with Windows reading media properties of the file thereby keeping the file in use by the operating system.PB
Most accessible formats for web?
By Xavier in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 00:45 -
Win 7 msconfig boot menu not accessible
By johns0 in forum ComputerReplies: 2Last Post: 10th Feb 2010, 04:21 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
USB devices not accessible using Explorer
By mats.hogberg in forum ComputerReplies: 4Last Post: 24th Sep 2007, 16:22
