Hi I have a tv show colletion on 7 (most likely dvd-r) discs coming to me in the mail and i need to make alot of copies of these ASAP..However i have a few questions....It is my understanding (and please correct me if i'm wrong) that u can't burn another copy on a different disc of an already copied dvd-r (like the dvd-r's i'll be recieving)......Soooo do i just copy it to my hard drive and then copy it to a dvd-rw and then to a dvd-r??? Should i make copies of the discs on RW discs so i can burn them directly instead of always burning them from my hard drive....After all my hard drive isn't the biggest and it takes at least an hour when i do it the way i've been doing.....I hope this makes at least some sense....Basicly i'm just wondering if anyone can tell me the fastest and most efficient way to burn these dvd-r's........Any info or help would be greatly appreciated.....By the way I have a Lite On 8x Dvd R/RW burner...A Hitachi Dvd ROM drive....DVDdecryptor...and clonedvd if that helps....Thanks again
depends on your setup and how many you really want to copy of each. easiest way is to copy on the fly, thats if the discs aren't protected. if they are protected your gonna have to put em on your hard drive anyways. if you plan on making multiple copys of each i would put em on your hard drive, save your (rom)drives the stress(longer life) and does write a little bit quicker.
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:50 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 02:09 -
Quickest way from Camcorder to DVD
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 26th Aug 2009, 14:07 -
What is the quickest way to get an mpeg onto a playable dvd?
By pugvader in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2009, 15:57 -
Quickest Way to Rip My DVD's?
By Rjupiter in forum Newbie / General discussionsReplies: 16Last Post: 19th Mar 2008, 14:11
