My GSA 4040B drive appeared to install ok in Win 2K but Record Now v 4.5 (came with drive)only partially recognises its existence.
The RecordNow wizard allows cloning of a CD/R and creation of a Data disk however the main screen shows all the menu "Drive" options greyed out and there is a pop-up at RecordNow application launch which states that no suitable drive was found.
Unable therefore to create any DVDs or use the Ram drive options.
The drive indicates A301 firmware (no changes by me)
the Stomp website is poor in information, anyone any ideas?
The main program does not recognize the 4040 but I'm able to burn DVD+RW's with the wizard.
I'm running A302 fw and have the pxEngine507 installed.
http://patches.sonic.com/downloads/engine/pxEngine507.exe
I dont think RNM will ever support it so you'd better use Nero 6 with the LG...
Disc drive not recognising discs
By Dankriss in forum Authoring (DVD)Replies: 8Last Post: 10th Oct 2011, 16:02 -
Verbation 16x and GSA-S10N drive
By webstar in forum MacReplies: 4Last Post: 23rd May 2010, 01:15 -
LG GSA-H55N drive doesn't load
By Cheesie in forum DVD & Blu-ray WritersReplies: 11Last Post: 20th Aug 2008, 06:23 -
Drive problem- LG GSA-H10L
By pinetop in forum ComputerReplies: 9Last Post: 17th Apr 2008, 02:39 -
Slow DVD drive (LG GSA-H42N) problems
By cosmo09 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Sep 2007, 01:51
