Being disappointed with the audio conversion of TMPGE, I find it so "tinny", I tried to use an external encoder. Toolame was suggested in this forum, I get getting an error message suggesting that an external encoder was unsupported or words to that effect. I have checked the external encoder box for mpg2 etc...
Any ideas?
I had the same problem with tmpge, I also found the sound was crap. Then I discovered it was only crap when trying to covert the sampling frequency eg 48khz=>44.1., otherwise TMPGE is really quite good with the sound. If youre ripping DVD to VCD etc use DVD2AVI to convert the sampling freq + Normalise first. Then you will find the sound is perfect
Probably it wont be perfect
but D_Head is right, the biggest problem with TMPG audio conversion is downsampling.
Select at least 48>44,1 "high", even better "ultrahigh". -
On 2001-10-24 09:34:03, hadoken wrote:
.. I get getting an error message suggesting that an external encoder was unsupported or words to that effect. I have checked the external encoder box for mpg2 etc...
Any ideas?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Check the "layer-2" box and browse toolame.exe. Make sure, you have a temp directory defined: option> enviromental setting> general. -
Still can't get toolame to work as external encoder, keeping getting "toolame.exe can not be used as external encoder" message. I have made sure I have a temp directory, but what about output file option, it's currently blank. Any more ideas?
Many thanks. -
D-Head and Truman: use a external downsampler together with toolame, that will take you longer encoding time, but pays back in better encoding quality.
I recomend SSRC for good speed and qulity. Wavesf44 is good quality but very slow, SCMPX is also very slow. SSRC is the best from my limited testing (in terms of speed).
Here is the link for SSRC http://www.milky.ne.jp/%7Egalaxy/
hadoken: try dowload Toolame from another place (i recomend http://www.doom9.net - downloads) to ensure that you have a good compile of toolame. Using Toolame should be pretty easy. What version of TMPGenc are you using?
<font size=-1>[ This Message was edited by: lupus on 2001-10-24 22:38:46 ]</font> -
lupus, I recommend to use ssrc with the Azid/ Lame GUI to have more options when you downsample the audio.
Yes, I have the Azid/Lame Gui, but i donīt use it for SSRC resampling, i dontīt bother using it because i think that using it from whitin TMPGenc it is pretty good as it is. (and i am lazy (-; )
When i use it i just use it for the Azid dolby digital to pro logic downsampling (pretty snazzy).
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 18:43 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 07:22
