Hi,
I have connected my VCR to the line in of my audio processor (Realtek ALC650 onboard a Gigabyte 8INXP). My stereo is connected to the line out. I have no trouble capturing audio but there is one annoying problem:
whenever the VCR is on, I can hear the audio through my stereo even if no capture program is running. The only way to turn this off is to either disconnect the audio cable or to turn off the "line in" in sound options. I can even hear it if I mute the "wave" option in sound settings which usually controls all outgoing sounds (mp3 etc).
It's not driver related, I have tried several driver versions.
Is there anything I can do/change so that I only hear the sound when I am actually capturing?
Thanks in advance,
Jenn
Turning off the "Line Input" is the only way to stop the sound. The "WAV" input is only for internally generated audio and has no effect on external inputs like microphones and line inputs.
Think of your audio system as a mixer console (which it eesentially is) with all inputs switched. If you don't have the volume controls zero'd and the inputs are switched on then whatever is on the inputs will appear in the output stream.
If you don't want an input then you have to either switch it off or zero the volume control.Artificial intelligence is no match for natural stupidity. -
Thanks for your reply. I had a hunch that that was the only option but I thought I'd ask the experts on this board here
I have put the volume control in my taskbar now so switching the "line in" on and off doesn't take much time.
Thanks again, I appreciate your reply and input.
Jenn
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 14:03 -
Subtitle Line Up problem
By ihmcjacky in forum SubtitleReplies: 3Last Post: 1st Jun 2009, 06:23 -
i bought 3 movies on line but they don't download they play from on-line
By N8DOGB4000 in forum Video Streaming DownloadingReplies: 6Last Post: 10th May 2008, 16:20 -
Help capturing line in audio
By djain91 in forum AudioReplies: 1Last Post: 22nd Nov 2007, 17:58 -
Srt2Sup - new line within subtitle problem.
By mattstan in forum SubtitleReplies: 3Last Post: 17th Sep 2007, 13:18
