i used to place svcd on to a dvd fit 2 on one
but recently cant seem to get dvdlab to work, used to work but had to rebuild my machine
since have had no luck convertin any svcd
pops up with a error message...
--> Cause: Not a 11172 or 13818-2 Video Stream
--> If This is a capture from TV it may have missing/wrong header
--> Please go to Tools to try Fix Stream headers on the file
i go and do this, dvdlab then says nothing done
and i get the same again, any ideas?
atfer trying a svcd i have put on to a dvd and had work it seems that doesn't work now...
was wondering, when converting do i need to get the correct codecs?
i use that ffdshow thing or whatever it is, and no others... used to have loads of different ones on the old pc
anyone know if this may course the problems??From The End To The Start It Begins In The Middle
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 08:21 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
DVD Lab Pro Play all
By milway in forum Authoring (DVD)Replies: 5Last Post: 10th May 2008, 04:10 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
DVD Lab Pro - Play Chapter and return to menu
By SCDVD in forum Authoring (DVD)Replies: 4Last Post: 5th Dec 2007, 16:05
