Hi there,
i ripped some dvds with davideo3 to hard disk with all contains and menus.
But when i'm going to play the files with power dvd or win dvd i can't click the menu buttons, its just the windows mouse pointer. Keys don't work, too..........
I am only able to play the .vob file manually, but then i can't change between the ac3 streams.
One strange thing: if play a rip with ac3 german+english it depends on the player which stream is heard. Win DVD mostly plays english, Power DVD mostly german........
What can i do to access the menus???
Is there a way to change between streams in manually playes vob files??
THX for all help!!!!!!!
Well, I would suggest giving DVDshrink a try. It's free and it works great. I've never had a problem getting it to rip the menus properly. I say this because it sounds like there's a prolem with the ripping software/process.
I've never used davideo3 before, so I don't know abouit that.
Can you rip a dvd without the menu requirement...plz read for nfo.
By darkcyber in forum DVD RippingReplies: 5Last Post: 11th Jul 2011, 22:45 -
How to rip BD with top menu + hd audio?
By dougw03 in forum Blu-ray RippingReplies: 6Last Post: 10th Jun 2011, 13:55 -
How to rip (DVD,HD DVD, Blu Ray) with chapter and menu in 7WMC?
By timf79 in forum Blu-ray RippingReplies: 1Last Post: 19th May 2011, 22:34 -
Rip DVD menu audio
By Silver_Ice in forum AudioReplies: 7Last Post: 27th Mar 2008, 23:33 -
After rip DVD menu not working, any suggestion?
By taylor6698 in forum DVD RippingReplies: 1Last Post: 3rd Oct 2007, 15:10
