I've got a firewire connection and a Canopus ADVC-100.
Any links or tutorials would really help. Thanx
K, I just converted my video to DVD. If there is a way to record from a dvd player to a vcr, I'd take this route.
Anybody?
Also, did I post this topic in the wrong section? If I did, where should I post it? -
You need a video display card that has a video out and a sound card that has audio out. You connect these to the VCR "IN". There you go!
Sam Ontario -
Originally Posted by Tic-Tok
Regarding the DVD to VCR question, just connect the DVD player to the VCR. -
I'm using a jvc HR-S2911U and a pioneer DV440. The JVC has AV-in slots in the front. I connected the AV-cables from the pioneer out to the JVC in. I pushed play on the DVD player and record on the vcr. However it didn't record.
I didn't hook up the players to my TV. Should I? and or are there any other reccomendaions?
Thanx for the replies... -
Make sure the VCR input is set to the FRONT A/V input jacks. Try the channel up or channel down buttons on the remote. On my JVC VCR, the front A/V inputs are designated as F-1.
It would be a good idea to hook the TV to the VCR so that you can monitor what you are doing.
Brainiac
audio gets out of sync when I record to VCR
By lipwak in forum MacReplies: 5Last Post: 26th Feb 2011, 17:39 -
how do i record VCR to PC help
By shockwave972 in forum Capturing and VCRReplies: 1Last Post: 10th Apr 2010, 04:57 -
Record from PC to VCR
By totomomo in forum Video Streaming DownloadingReplies: 4Last Post: 7th Mar 2010, 02:25 -
record comcast hd box and VCR/DVD
By ranger_cole in forum DVD & Blu-ray RecordersReplies: 8Last Post: 17th Jan 2009, 21:50 -
useing a tivo type unit to record from a vcr
By 2boot in forum RestorationReplies: 0Last Post: 20th Feb 2008, 18:36
