  1. has anyone got this to work.
    I want to try burning a svcd disk after encoding it with the tmpgenc templates but how do I cut it with winoncd.
    it seems to not accept it.
    What are people using to cut mpeg2's onto a cd with full menuing system?
    Thanks for any assistance you can give?
  2. 1. Make an AVI file with Flask or s/t like that
    2. Cut it with VIRTUAL DUB
    3. Encode with TMPEG
    Thats it !
  3. Thanks for the reply
    I'm able to create the mpeg fine but its the cutting to the disc that I'm having problems with. What authoring program should I use for svcd files cos winoncd can't handle it
  4. Follow ultradna's advice. I know you are able to encode to svcd. The point is, try to do all your editing - cutting - trimming in the avi stage using virtualdub before you start encoding to svcd. That way you shall be saved many headches later.
    So the process from dvd would be like :
    DVD2AVI -> vfapiconv -> virtualdub -> tmpgenc.
    If source is in avi, then just virtualdub -> tmpgenc.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    But if you really need to cut try BBMPEG
    http://www.vcdhelp.com/bbmpegedit.htm
  6. maybe I'm using the terminalogy all wrong here.
    I'm not trying to edit nor cut, I'm trying to "write" my mpg2 files to a svcd. What authoring program are people using to have nice animated menus. Winoncd allows you to have a mpg file which you can then associate menu selections of it. Nero can't do that? can it...
