Have been using clonedvd with anydvd without problem for a few weeks. Then stupidly I downloaded DVDShrink and Nero and everything started playing up so I got rid of shrink and nero but now everytime I try to get clone to read a dvd it gives this message.
OD:\VIDEO-TS/VTS-01-2.VOB:23:readerrorTCE
This can happen anywhere between 0% and 100% read. I uninstalled clone and reinstalled latest version, still same prob. This even happens on dvds that clone has previously read and burnt without problems before.
I hope I have made some sense and that someone can help
If you just uninstalled Nero or erased it, it's probably left some remnants. The Nero site has a Nero remover that should be used when dumping the program. I personally use DVDshrink and DVDdecrypter to burn. Nero is fine for some things but it messes with your system at times. Download Neroinfo Tool 207 it's handy for seeing your drive settings and your ASPI layers and which ones you have. ASPI could also be your problem.
Clonedvd 2 question...
By ironmanDD in forum DVD RippingReplies: 1Last Post: 20th Jan 2011, 23:41 -
CloneDVD aspect ration problem
By godftw in forum DVD RippingReplies: 13Last Post: 6th Aug 2010, 16:13 -
CloneDVD Feature Question
By jeanpave in forum DVD RippingReplies: 4Last Post: 7th May 2010, 03:26 -
Do i have to get clonedvd?
By blaqlion22 in forum DVD RippingReplies: 3Last Post: 30th Jan 2008, 10:28 -
CloneDVD or Shrink?? Which is Better?
By Jonathan in forum DVD RippingReplies: 15Last Post: 22nd Dec 2007, 20:52
