I have ripped the audio from a music dvd so i can play it in my car the only prob i have now is the wav file is like 1gig how can i make this smaller in size?
Size of Format: 16
Format: PCM
Channels: 2
Samplerate: 44100
Bytes/Sec: 176400
Block Align: 4
Rip each chapter one at a time, assuming each chapter is each song title. You may need to alter 176kbps back to 128kbps... not sure. Others will know how to do this..right?
I'm assuming since it's a "Music DVD" is has a LOT of songs on it, which would mean that it wouldn't be able to fit on a single CD.
Once you have each track (chapter) ripped separately, you should be able to burn them onto a CD normally as you would with any audio tracks. (Some software may require the audio to be in a certain format)
Good luck.
No Audio on ripped DVD
By BigNoise in forum AudioReplies: 1Last Post: 17th Jul 2009, 20:57 -
audio doesnt play with the ripped video
By BigNoise in forum DVD RippingReplies: 4Last Post: 17th Jul 2009, 18:27 -
Ripped with DVD Decrypter - No Audio
By ezen in forum DVD RippingReplies: 7Last Post: 22nd Oct 2008, 00:05 -
Ripped DVD Audio to iPod
By Squid_uk in forum Newbie / General discussionsReplies: 3Last Post: 19th Oct 2008, 11:08 -
Choppy audio and video from ripped dvd
By louthewiz in forum DVD RippingReplies: 1Last Post: 15th Dec 2007, 01:35
