Some days ago, I posted I found a solution for ff/rw problem using DVD2SVCD.
I created a SVCD video of about 1h20m with chapters and great fast-forward/rewind.
I was happy, so I wrote it.
Now I've tried to do it again.
And guess?
It doesn't work!
I can't believe it.
I've tried several settings, tried to remember what I've used that day.
What's happen?
Something similar happened to me a while ago. I had a 50 min. SVCD which *did* FF/RW OK (the time display was wrong though I think).
As it turned out, the FF/RW worked because I had a 35 min SVCD (which did ff/rw fine) in my player just before I inserted the 50min CD in the player. By the way, FF/RW would *not* work after the 35 minute point. Appearantly, the player remembers something from the first SVCD (probably some scan data).
This sounds strange but it's reproducible.
Anyway, do you still have your original succesful SVCD? Does it work now or has it stopped working properly (ff/rw and time display)? -
No, I haven't anymore. It was a CD-RW and erased soon.
Are you saying that if I load a <30min first, than the next disc >50min works well?
Do you think "Philips SVCD Designer" work well?
DVD ripping nightmare
By julius02 in forum Authoring (DVD)Replies: 22Last Post: 17th Aug 2011, 16:02 -
dish dvr 722 external hd to pc
By desiking911 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st May 2011, 12:21 -
AMD's Zacate APU will be incredible
By deadrats in forum ComputerReplies: 3Last Post: 14th Nov 2010, 18:44 -
The U2 3D IMAX movie is incredible!
By Epicurus8a in forum Off topicReplies: 2Last Post: 4th Feb 2008, 16:29 -
The Incredible Disappearing Warranty Receipt!
By CobraPilot in forum ComputerReplies: 10Last Post: 27th Oct 2007, 00:12
