I have a XVId clip whose audio is ac3 188,287KB, I have converted this using both Ac3tool & Headache to a WAV file and it has increased to 630MB which is more than that of the video itself. I have no need to encode, so what can I do to reduce the WAV before merging the audio and video together with virtualdub? I also tried converting it to an mp3 file which was around 57MB but I cannot merge the mp3 audio and video avi using virtualdub can I?? Please tell me what is the best option thanks![]()
Results 1 to 11 of 11
ac3 is highly compressed ... wav is not compressed .. therefore it will get larger ...
BEST option is to leave it as ac3 and xvid ... and dont do anything to either .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
But it has to be converted to be heard, if I leave it is as it is I can't hear it and plus I need to mux both video and audio using virtualdub. Perhaps there might be a way of recompressing the wav audio to make it smaller?
. Thanks BJ M however, if u could offer any further help it would be much appreciated or anyone else for that matter cheers.
I am not quite sure if I have made myself clear. I need to remux the audio and video to a reasonable size so I can burn it to disc. It's not for my pc.
I worked it out myself dude. I first converted the ac3 to wav, then to mp3 as it seems you can't convert it directly, then merged the audio/video using virtualdub mp3. This resulted in a nice tiny mp3 file unlike the huge wav. For those interested in my case it was going to be a dvd so I formatted it with 48hz sampling rate. Thanks for your input anyway and I hope mine helps future members
Again another person asking for help without CLEARLY telling us what it is they need or exactly why they are doing it. Also not enough details about the source materials either.
You newbies gotta learn!
dvd's use mpeg2 and ac3 (or lpcm) --- so your whole post makes no sense what so ever ...
unless you have a dvd player that plays divx .. but those also will have played the ac3 ..... so you didnt have to anything ...
plus the conversion from ac3 to wav , back to mp3 really wacks the quality of the audio anyway ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Yes FULCILVES John Coleman that's true I was asking for help not your SARCASM, but if that is all you can afford God help you my friend.
BJ M in response to your post. That's just it I DO have a divx player. But still feel the need to convert the ac3 audio to a format that will play on disc. The file as it comes has no sound it has to be converted to something. I accept that if you are making a DVD movie then perhaps the audio does have to be mp2/pcm, however, I was just burning an xvid clip with ac3 audio. Anyway let's forget it as I said before I have solved it my way and the film's fine.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 04:03
