Hi!
Here's the problem:
I ripped video to M2V file, which plays good in a soft player (LiteAlloy), is 2:13 , size ~7Gb and everything else is OK.
I open this file in Canopus Procoder, change the output bitrate, set Mastering Quality. Everything else remains unchanged.
So after 14 hours I get a M2V file that's about 3GB, but, when opened in the LiteAlloy, it shows the length about 45 mins, and playback is very jerky. Looks like a bunch of frames is just missing! However the entire movie is there, including end titles...
Does anyone know how to re-encode M2V file with ProCoder and get a correct M2V on output? What's wrong with Procoder anyways?
Any help would be appreciated,
Results 1 to 13 of 13
~XAWE~
nothing wrong with it ....
did you set source video type, aspect ratio , frame rate , etc ?
did you set target video type, aspect ratio , frame rate , etc ?
there are a LOT of settings to do in target (hit advanced ) and if not done -- it will look like crap ...
mastering takes a LONG time .. btw ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
hmmm... don't see anything wrong with settings..
source:
FrameRate: 29,97
Non-Interlaced, Video: [16:9]
(I took it from DVD2AVI output, trustworthy?)
Target: MPEG2 Elementary Stream, 720*480, 29.970 Frame Rate, Non-Interlaced, Aspect Ratio: 4:3, Mastering Quality, 2PassVBR, VideoBitrate 3500-6000, DC Precision: 10... That's it. But doesn't work.~XAWE~ -
sounds like it had a pulldown applied -- maybe even a non standard one ..
maybe not though, but -- 29.97 is ussually interlaced , not progressive.
did you step through frames and see if there is a cadance ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Actualy you're right, 29.9 is not progressive...
Question: HOW?did you step through frames and see if there is a cadance ?
Actually, I loaded the source M2V into VirtualDub, and in "File Info" it says 23.9 fps, however Procoder doesn't let me change the frame rate from 29.9 to 23.9, it's just disabled.. I'm confused...~XAWE~ -
ahhh - ok ...
a little more info always helps
use pulldown.exe (get it here) on m2v file ...
you will be left with another file same size but new name..
load that file into procoder ... procoder source should say 23.98
for target -- couple of options ... i'll tell you the procoder way first:
set dvd as type
29.97
uppper field first
select advanced to get further menus
under pulldown - select 23.98 (never mind tool tip as it makes no sense) , never mind pulldown filter in adv options as it is for something diff - which i have not got to work)
and set other settings as you need ...
done ...
my way
select mpeg2 as type - instead of dvd and set everything by hand
select progressive encoding - no pulldown - 23.98 frame rate
turn off dvd compliant ...
etc etc etc ...
then use pulldown.exe again on result - except this time ADD pulldown in options ...
done"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
wow, thanks for the explanation! I'll try this trick with pulldown
~XAWE~ -
btw: is there a tool that gives out all the info about an M2V file like fps, aspect ratio etc ?
~XAWE~ -
bitrate viewer or dvd2avi
and others in the tool section"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hey BJ_M!
need your help once again
I did everything you've said, and produced a perfect progressive 23.970fps m2v which plays ok in a player.
Now, I need to enable telecine on it, and I'm trying this
pulldown src.m2v dst.m2v -prog_frames p -framerate 23.976
but it doesn't work. resulting movie is jerky again and has length of 1:05 instead of 2:13...
What would be the right way to enable pulldown on 24fps mov ?
pls help
~XAWE~ -
pulldown srv.m2v dst.m2vOriginally Posted by XAWE
That's all
- John "FulciLives" Coleman
P.S.
This will apply 3:2 pulldown to a progressive 23.976fps movie so that your DVD authoring software sees it as 29.970fps"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
yep -- what he says
Used Deshaker on a footage, but bad result. Please help.
By namphong0612 in forum EditingReplies: 12Last Post: 11th Jan 2012, 22:13 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
FFmpeg options ? Bad result on a standalone
By Umen Pich in forum Video ConversionReplies: 4Last Post: 18th Jan 2009, 09:28 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 03:56
