I purchased a ATI AIW 9800 PRO from NewEgg.com a few weeks ago. The card worked great for the first day or so then I started to get five vertical lines on the screen. They went away when I refreshed the desktop but it was annoying so I did an RMA with NewEgg. The new card came yesterday and again, it was GREAT for the first four hours or so. Suddenly the screen became distorted while burning a CD. I simply rebooted the machine and it was fine. It then happened again only this time when I rebooted the computer the problem started the second it started to reboot and went all the way into when Windows loaded. It shows up also when I boot into Safe Mode.
I have unistalled the drivers, I have changed the screen resolution, monitor refresh rate and everthing else that could possibly be changed but nothing has worked.
please check out this link, i have taken screen shots of the problem
>>LINK<<
My computer specs are:
WIN XP SP2 Home
-Gigabyte Motherboard: GA-8IPE1000 Pro
-Intel Pentium 4 - 3.0Ghz with HyperThreading
-I Gig of Ram (dual 512 Sticks)
-ATI All-In-Wonder 9800 Pro
-Audigy LS
-Antec Case with 350 Watt
I HAVE NOT DONE ANY OVERCLOCKING EITHER.
PLEASE, if anyone can help I would appreciate it. Let me know if I have left anything out also. I would hate to have to do another RMA but it looks like it will probably be the case.
I hate to say but I think your video card is fine.
It's your monitor that's taking a crap.
If you have another computer hook it up that one and see if it still has the lines.
This wouldn't be the beta SP2, would it?Originally Posted by ah577
If the monitor was at fault, then surely the distortion wouldnt be on a screen capture? Unless you took a photo of the actual screen?
I had a similar problem years ago with an IBM pc with on-board RageII-C graphics
,turned out to be a bad graphics chip.
**edit** just noticed your spec states a 350W PSU. That could be your problem there. Thats a lot of system to be powered by 350W.We'll be right back after these messages from Binford!
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 18:41 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
Philips 5990 -when connnect to TV, screen color distorted
By fayewolf in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th Apr 2009, 01:36 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 15:17
