I've been fooling around with DVD-lab for creating DVD's with menus, etc and it's a great program.
However, I'm wondering what program would be best to simply burn an .MPG onto a DVD so when I stick my DVD into a player it will start playing the movie.
I don't want any menus or anything. Just a very simple DVD that plays the movie.
DVD-lab appears to be able to do this, but I'm not sure if that would be my best choice or not.
sofakng
Get Ifoedit. It's free--see tools section. Works great. No menus, but you can easily add chapter points from a text file. I usually have a "standard" text file that puts a chapter point every 5 min, just to advance through the video very quickly in the even you accidentally hit the "stop" rather than "pause" button in the dark. Give it a try.
wwaag -
dvdauthor 0.6 will do the job. It is free and command line based so you could make a script that will allow you to push a button and get the VIDEO_TS and AUDIO_TS directories.
- 1. Split video and audio stream using TMPGen free copy or VOBrator or Rejig.
2. Remerge video and audio stream with dvdauthor tool mplex:
mplex -f 8 -o video1.mpg Source.m2v Source.ac3
If the source had MPEG 1 layer 2 audio then change the last file to Source.mp2
3. Make a simple xml file:
Code:<dvdauthor> <vmgm /> <titleset> <titles> <pgc> <vob file="video1.mpg" chapters="0,5:00" /> </pgc> </titles> </titleset> </dvdauthor>
Note: you need to manually list all the chapter points after the chapters= statement. The format is hours:minutes
econds.fraction.
4. dvdauthor -x Simple.xml
There is also DVDAuthorGUI that may be a bit easier.
Ulead's Movie Factory will work as well but costs $40. If you already paid for DVD-Lab then I would suggest that you use it. If I recall correctly, it would take only a few steps:
- 1. Load MPEG file
2. Drag movie and audio to Movie clip in the connections window
3. Connect First Play and Title button to movie by drawing a line from each white circle to the movie clip.
4. Compile
5. Burn.
If you don't own DVD-Lab then buy something cheaper like Movie Factory.Ted Rossin
http://www.tedrossin.0sites.net/ - 1. Split video and audio stream using TMPGen free copy or VOBrator or Rejig.
The problem is few standalones will play ISO MPEG,most Chinese players(Apex,Mintek,Cyberhome,etc) will.Most standalones will only recognize MPEG's in file mode(IFO,BUP,VOB).
I use Ulead Videostudio 6 to author and make chapters then use DVDShrink to remove menus and transcode.
What Program was used to create these menus?
By BIGD22 in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2011, 19:43 -
A simple but affective program that i can simply place different avis and cut?
By Mozzy31 in forum EditingReplies: 5Last Post: 10th Feb 2010, 07:56 -
Best program to create a DVD (with menus) from MP4s?
By namrufmot in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2010, 22:18 -
Program that allows direct VOB burning AND menus
By 6079 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2009, 06:15 -
Looking for a presentations program to make dvd menus
By faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 11:00
