  1. I'm using DVDShrink in re-author mode to create a compilation DVD from titles that I have ripped on to my hard drive. Ideally I'd like to have 50-100 small clips on a single DVD when I'm done. I'm isolating the clips by dragging the title I want over and using the start/end feature to select the clip. Since I'm working with so many titles, I want to be able to save my work without actually generating the output, so I can go back later and adjust the clip size.
    Unless I'm missing something, which I hope I am, I cannot save my work without actually doing a Backup, but once I do that I can no longer adjust my clips. Can someone suggest something that I might be missing?
  2. Hi FlittyBlitzman.
    I'm affraid you're right in thinking you have to backup to save your work, which defeats the purpose.
    As far as I know there's no workaround for it, unless you backup and "tweak" each clip separately before making the final compilation.
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
