I just started using canopus procoder the other day and it's working great. However, I'm not sure exactly how to encode multiple files each to their own separate type. In other words, I load up the 2 files to convert in the first tab in the second tab I choose an mpeg2 output and an avi output. I want the first movie to be converted to mpeg2 and the second to convert to avi. However, when I press convert it converts each file to mpeg2 AND avi. How can I specify a file only to be converted to ONE specific type? Sorry for the confusing explanation. Thanks ahead.
yea -- i got confused on that also ..
there is a thread on the canopus procoder forum for registered users that explains this in detail .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Yeah, i use Procoder.....
Fantastic results with a few simple clicks!
The way you want to batch the procoder encodings is not so easy todo.
First you have to create a droplet with the right settings and then call them with a batch script from the command line.
It's really cumbersome.
The exact procedure is somewhere in the manual i think.
I have briefly tried to get it to work but without success. -
yeah, ill have to check the the registered forum. heh....sounds like a pain for a so called easy program
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 05:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
