    Mar 2004
    Kansas City
    Hello all: I am trying to create an svcd and I am having serious sync issues. I run Linux, and have captured using dvgrab, converted using transcode and now I am trying to combine the streams for burning using mplex. Everything is fine, except that I can not adjust the time difference between the audio and video using the -O option like the manpage states. Here is the command I am using as well as the output:
    mplex -f 5 -b 230 -O 200 -o test1.mpg test.m2v test.mpa
    INFO: [mplex] mplex version 2.2.1 ($Date: 2002/02/04 19:06:14 $)
    INFO: [mplex] File test.m2v looks like an MPEG Video stream.
    INFO: [mplex] File test.mpa looks like an MPEG Audio stream.
    INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
    INFO: [mplex] Selecting SVCD output profile
    INFO: [mplex] Scanning for header info: Video stream e0 (test.m2v)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 480
    INFO: [mplex] Frame height : 480
    INFO: [mplex] Aspect ratio : 4:3 display
    INFO: [mplex] Picture rate : 29.970 frames/sec
    INFO: [mplex] Bit rate : 2500000 bits/sec
    INFO: [mplex] Vbv buffer size : 229376 bytes
    INFO: [mplex] CSPF : 0
    INFO: [mplex] Scanning for header info: Audio stream c0 (test.mpa)
    INFO: [mplex] AUDIO STREAM:
    INFO: [mplex] Audio version : 1.0
    INFO: [mplex] Layer : 3
    INFO: [mplex] CRC checksums : no
    INFO: [mplex] Bit rate : 16384 bytes/sec (128 kbit/sec)
    INFO: [mplex] Frequency : 44100 Hz
    INFO: [mplex] Mode : 0 stereo
    INFO: [mplex] Mode extension : 0
    INFO: [mplex] Copyright bit : 0 no copyright
    INFO: [mplex] Original/Copy : 0 copy
    INFO: [mplex] Emphasis : 0 none
    INFO: [mplex] SYSTEMS/PROGRAM stream:
    INFO: [mplex] rough-guess multiplexed stream data rate : 2680400
    INFO: [mplex] Setting best-guess data rate.
    INFO: [mplex] Sectors = 78 Video delay = 52376 Audio delay = 48692
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
    INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [mplex] Scanned to end AU 62130
    INFO: [mplex] STREAM e0 completed @ 62130.
    INFO: [mplex] STREAM c0 completed @ 79360.
    INFO: [mplex] Multiplex completion at SCR=186608425.
    INFO: [mplex] Video e0: buf= 158764 frame=062130 sector=00275517
    INFO: [mplex] Audio c0: buf= 753 frame=079360 sector=00014447
    INFO: [mplex] VIDEO_STATISTICS: e0
    INFO: [mplex] Video Stream length: 78693456 bytes
    INFO: [mplex] Sequence headers: 3485
    INFO: [mplex] Sequence ends : 1
    INFO: [mplex] No. Pictures : 62131
    INFO: [mplex] No. Groups : 3485
    INFO: [mplex] No. I Frames : 3485 avg. size 18287 bytes
    INFO: [mplex] No. P Frames : 17259 avg. size 10660 bytes
    INFO: [mplex] No. B Frames : 41387 avg. size 9225 bytes
    INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
    INFO: [mplex] Average bit-rate : 2429200 bits/sec
    INFO: [mplex] Peak bit-rate : 2750400 bits/sec
    INFO: [mplex] BUFFERING min 15 Buf max 118252
    INFO: [mplex] AUDIO_STATISTICS: c0
    INFO: [mplex] Audio stream length 33169659 bytes.
    INFO: [mplex] Syncwords : 79361
    INFO: [mplex] Frames : 3239 padded
    INFO: [mplex] Frames : 76122 unpadded
    INFO: [mplex] BUFFERING min 15 Buf max 432
    INFO: [mplex]
    INFO: [mplex] MUX STATUS: no under-runs detected.
    Everything seems fine to me, however there is no difference in the mplexed signal than if I didn't try to change the syncronization at all. Any help would be greatly appreciated, thanks
    Shane
    Linux = Complete_Control
    Apr 2003
    Yes I found that to be true as of latley. I use kavi2svcd to set the mplex options for me. It also has an option for another program to mplex the streams back together(Can't rember which one I'am work right now). This one work when the one from mpjeg tolls dosn't.
