Hi,
Currently I have an aging Panasonic E20, and it writes only to DVD RAM. My primary PC has capability for DVD RAM and DVD +RW/R -RW/-R and what not... however the rest of my family has dual format but NO DVD RAM capability on their PC's.
I would like to aquire a DVD +RW recorder to put cartoons and what not on more easily than having to put them on my system, then convert to DVD +RW ... however the Panasonic E20 permits editing of the content (I can remove commercials, and save space).
Are there DVD +RW recorders which support this capability, and if so, which if any are the low cost units?
Thanks for any help!
All DVD+RW/+R units will edit out commercials. The biggest diffence is that on DVD-RAM you can re-use the space you saved by editing the commercials, on DVD+RW you cannot.
Ouch, is there a utility to figure out what was edited out to help recover the lost space? I really like recovering the space on my ram drive... and could live with the +rw drives not recovering the space, IF there was a utility to later go over it and remove the skipped portions.
Thanks by the way for your help... also suggestions on low cost units would be helpful. -
Don't do it. The method is flawed. My site will explain it more soon.
If you want to edit, use a PC.Want my help? Ask here! (not via PM!)
Get the Panansonic E80 with the hard drive to edit its the best way to do it on a DVD recorder. Also PC is very good to edit.
Removing commercials from a DVD video
By solarblast in forum Capturing and VCRReplies: 9Last Post: 10th Sep 2011, 04:35 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 19th Oct 2010, 00:09 -
Are there DVDRs on the market that would permit copying protected TIVO ?
By jbriley3 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 25th Sep 2010, 12:21 -
Accurately editing commercials from HD PVR h.264 .ts files
By finallygreen in forum Video ConversionReplies: 10Last Post: 28th Oct 2009, 15:14 -
Blu Ray commercials on DVD
By INFRATOM in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 09:13
