I am having a problem Converting Vcds To play on my Pioneer 343 which does play vcds. It plays other vcds fine. The VCD that I made plays fine on my computer when I burn them but it will not show a picture when its in the dvd player.The Dvd player reads Vcd but just shows a blue screen. I'm using Video wave 4 and I have easy cd creator 5 (full version and have tryed many times but They want play in my dvd player which I know plays Vcds and I've used both imation cdr and memorex. Some one please help me Thanks.
you are right. that player should take cdr/vcds fine (having a dual wave laser) (svcds and xvcds as well) i only use nero to burn vcds . it checks the mpeg for compliance before burning. i have some cds on crap media and they played fine on an apex and a panasonic.
if the vids you have were an iso type (bin/cue or iso or such) try extracting the mpeg with vcdgear (available in tools here) then dropping the mpeg(s) in nero (make sure it says they are 100% compliant - perhaps your player doesnt like 23.976 frame per second vids - make sure nero doesnt complain at ALL) and then burn them.... if that still doesnt work take your player back
I have the same player and especially with VCDs (as opposed to SVCDs) it will play about any media. If you don't mind buying something else, try ULEAD VideoMaker 5 with the DVD plugin. It's pretty simple and works every time.
AGK conversion problems
By loninappleton in forum SubtitleReplies: 10Last Post: 9th Sep 2009, 11:48 -
Conversion problems with mencoder
By danielrhodes in forum Video ConversionReplies: 1Last Post: 14th Nov 2008, 22:37 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 03:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 01:40 -
film conversion problems
By hobo20212 in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2007, 08:52
