It seems that on my PC configuration, the TrueBlue Action encoder card is not compatible with Creative SoundBlaster Live! Value card. Whenever I connected the audio-in cables from VCR/TV to the TrueBlue card, the capture program hangs. If the cables are not plugged, the capture program can capture the video without any problems. Anybody has the same problem? I've tried downloading new driver for the Live! card but the problem still remains.
It took me a few months to discover this. There seems to be no new drivers for the TrueBlue card. Support on the website is no good at all.
Zaki, I also have a Trueblue Action (known as PV231 in the US) and I use the latest drivers from this website:
http://www.grandtec.com.tw/EN/download/download.html
Choose the "VCD2000Plus V3.2 AP & Driver".
This is a newer driver and application than the software on the Mediaforte site and works perfectly.
Guido
Lg-bd630 stutter problem solved!
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Feb 2012, 15:18 -
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 19:19 -
Problem with Avi-MuxGUI in Windows7 -Solved
By netmask56 in forum Video ConversionReplies: 0Last Post: 20th Jul 2009, 05:04 -
[SOLVED] 'fast action' with ffmpeg or Cinelerra?
By jdetwile in forum LinuxReplies: 2Last Post: 25th Mar 2008, 06:20 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 04:07
