One of these days I will get it right but here goes I use my d2v file and audio file then load them into tmpeg 2.0. For this example i am using a straight vcd ntsc disk I get jumpy video about 15 minutes or so into the movie. I have tried both field order I have tied both A first and B first and both have the same resaults. Could it be something the the de-interlace setting I am missing, right now I dont have it checked. If somebody knows the right setting that will make this go away I will really appreciate it.
Thanks a bunch In advance.
--Nick
If you create VCD, then you need to de - interlace your source! Do that always for resolutions 352 X 288....
I suggess: De-interlace (even fild/adaption) and set: top fild first A
Thanks for the great reccomendation I will try that, damn I wish it did not take so long to encode to try things out. For an (X)vcd which I will be doing once I get this going right, what is the best way to go constant bitrate at say 1800 or a 2 pass variable birate with an average of 1800, also how much longer will this method take.
Thanks a bunch -
I never really liked de-interlacing. I always use progressive framing, then convert again to VCD format using TMPGenc. You can do it straight through VCD format in Flask, but I get VCD compliant problems for some reason.
field order wrong after AVStoDVD conversion
By 4evrplan in forum Authoring (DVD)Replies: 18Last Post: 26th Aug 2013, 15:59 -
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 13:41 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Nero Vision 5 with ADVC-100 - wrong field order in NV5
By vcddude in forum Capturing and VCRReplies: 10Last Post: 28th Nov 2008, 17:22 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
