Hi guys i'm looking at buying some new media i am curently using the Bulqpak DVD-R 4x printable ProdiscS03, i've been having few problems with them mainly freezes etc, so i was wondering if the Ritek A Grade were a viable option? The RitekG04 ones, any ideas and opinions would be great thankyou.
All I can tell you is that I have used them many times without any problems, but I'm sure others will have different opinions.
Mike -
Yep i use it....
300+ Disks and no coasters no problems playing in any dvd player...
What more can i say.. :P :P
I buy nothing but these disks..Not bothered by small problems...
Spend a night alone with a mosquito -
Just which 1 of these disc's is the legendary Ritek disc in which so many preach..?
http://www.blankdiscshop.co.uk/acatalog/FOR_DVD_R_RW_CLICK_HERE.html
i use these ridata discs....any users/views who are familiar.>?
http://www.neogames.co.uk/product.php?xProd=488 -
{DV 3071/25} Ritek A Grade 1x to 4x Inkjet Printable DVD-R in pack of 25
Is what i use....
That stock had better arrive on time.....Not bothered by small problems...
I have also used these discs no problems with playing, the only problem that i had was printing on them using an Epson printer (not the original ink though!) which is probably the cause but no other problems.
as for the Bulkpac discs i used the +R brand and had the same problem with freezing so much so i bined the rest. -
No problems printing on them here..Originally Posted by Karlos
Use compat carts from "Choice Stationary" What setting are you using ? Could be you are using too much ink. I have wondered if they have changed the coating as it now seems to be OK on CD/DVD printing setting where as before i could use glossy paper setting no trouble...If i use it now they take ages to dry..
CD/DVD and 0 or +1 gives me a crisp clear image with a touch dry disk straight from printer.
Hope that helps you.Not bothered by small problems...
What printers print on Blu-ray inkjet printable media?
By videobread in forum MediaReplies: 4Last Post: 23rd Dec 2010, 18:08 -
Thermal or inkjet printable? How do I tell?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 29th Apr 2010, 01:46 -
Need Advice on Labeling Inkjet Printable DVD
By mn072065 in forum MediaReplies: 5Last Post: 7th Nov 2008, 04:15 -
Inkjet Printable DVDs - in what order and storage question
By richapple in forum MediaReplies: 4Last Post: 30th Jan 2008, 07:39 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 10:29
