Niggly question about xp pro folder option,my folder is now scrolling left to right and my preference is up and down. I can't seem to locate the option to change how you scroll, does anybody know how to.
Eh!.......don't know why it's doing that, it worked perfectly well on my system !!!!!!!!!!!!!!!
with regards to the folder problem I think I've solved it , I was messing about with the view options and if I had it set to "list" this is when it scrolled left to right, if i set it to "details" it scrolls up and down, go figure but problem solved
can't scroll through movie
By griggrig in forum Software PlayingReplies: 4Last Post: 18th Oct 2011, 19:11 -
Screen Video Streaming scroll to left
By n33 in forum Video Streaming DownloadingReplies: 2Last Post: 14th May 2009, 09:22 -
AVI files scroll when played on TV
By Mike_ in forum Newbie / General discussionsReplies: 9Last Post: 2nd Jan 2009, 13:01 -
Adobe Premier - scroll image vertically
By balonglong78 in forum EditingReplies: 5Last Post: 30th Dec 2008, 14:14 -
internet explorer : making a scroll bar
By mazinz in forum ComputerReplies: 4Last Post: 2nd Aug 2008, 05:14
