  1. I've been lookin for a conversion and so far none found it'd be of great appreciation if someone could tel me if its possible and if so show me how. Thanx!
    ~jimbo~
  2. Tmpgenc should convert asf to VCD compliant mpg file.
    See http://www.vcdhelp.com/tmpgenc.htm
  3. <font size=-1>[ This Message was edited by: chaobox99 on 2001-10-24 16:15:01 ]</font>
  4. where can i get TMPEG 1.3?
    ~jimbo~
  5. my bad, follow the link from daddywolf.
    I think I'll try to convert my audio file first.
    it might not be TMPEG 1.3. I don't know if i got the version right.('m at work right now, can't look it up) But find an older version of TMPEG. You will be able to load the asf file with that. I happen to downloaded that version a while ago. You should probably try Divx codec or Kristal studio pack codec first. They might work on the new TMPEG.
    If not, u'll have to find the old one. Good Luck!
  6. When I say 1.3, I was thinking about VirtualDub 1.3c.
    Anyway, u should be able to find TMPgenc12a at google.com.
