Hey, OK I wanna transfer my C drive over to a new and bigger hard drive. I'm running windows XP and it is installed on my C drive. I remember I tried this before and everything copied fine except for the user profile sections so I ended up formatting everything and starting with a fresh install. Some files were locked or something. Anyways I heard there were programs that will be able to transfer the files properly so I was wondering what they are if anyone knows. Thanks!
Use something like norton ghost that will create an image of the hard drive. You can then restore that image to your new larger hard drive. How big is your C drive now, you dont need that much space for OS and programs and even with a larger drive you should really partition off a small portion for your OS. If you just want more space for storage then get a large secondary drive and install it alongside your current C: drive.
I've used Powerquest Drive Image to do exactly this a couple of time, works like a charm.
Yes, I am a Pooternerd -
Well right now my Hard drives are configured a little funny. I have a 70gb C drive and another secondary drive that is 120GB partitioned into a D and E with 90GB and 30 GB respectively. The thing is I need more space! So I could install the new 250GB drive using SATA but I dont like my current C drive since it makes too much noise when loading. So once I transfer the data should I just partition the C drive? Maybe leave like 25 GB for the OS and then use the rest as another storage. Would it make the OS run any slower if I didn't partition it?
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
