Is there any benefit to ripping a disc first or to just let DVDShrink do it all?
Results 1 to 16 of 16
Nickolas
Unfortunately, some of us only have one dvd drive for playback and recording...which is my case...
Ripping then burning with the same drive has not caused me a problem in the last year and a half...
It's supposed to make the dvd drive last longer.. makes sense I suppose -
I believe in ripping to my HD:
a) as mentioned, prolongs the drive's life;
b) access times are less reading from HD;
It may or may not be clinically proven that using DVDShrink entirely will result in reduced lifespans for your DVD drives. I don't know for sure, but it makes sense that a drive running for 10 minutes will do more jobs than a drive running for 45. Also, ripping at around 8X-10X beats 2X any day. DVDShrink also encodes reasonably quicker off the HD than on the fly.If in doubt, Google it. -
Originally Posted by jimmalenko
Jimmalenko,
How do you get the drive to rip at 8x? I thought the ripping is locked at 2x?
JACK -
Originally Posted by jackmac
Originally Posted by bdf24
JACK -
Versions before 3.1 ripped slowly and sometimes wouldn't export any files on my system so I would use DVDDecrypter first.
jackmac,
Have you tried www.rpc1.org ? -
When I rip with just DVD Shrink, it will not play, on my DVD Burner, but it will play on my stand alone. But if I use DVD Decrypter first, on the same movie it will play on my burner, and standalone.
I believe it has something to do with the way DVD shrink handles the Regional codes. -
Originally Posted by MOVIEGEEK
Hey Moviegeek,
What program should I dl from rpc1.org? There seem to be a bunch of programs. I am using plextor 708-A by the way. Thx.
JACK -
Definitely use a DVD-Rom to rip. My burner only goes 2x, while the ROM tops out at 9x plus before the layer break. Also, I'm glad someone else thinks that later versions of Shrink rip faster, thought I was my imagination!
Pull! Bang! Darn! -
Hi all.
Originally Posted by fritzi93
This is for straight ripping though, when no compression/processing is involved. -
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
