anyone able to get the daytek p30 to accept hacked firmware? my cdrw just says "DATA DISC"
Results 31 to 37 of 37
Hi Guys,
I just bought a Daytek p30. Its a good machine, but am having a little problem on it. I've read many threads but this one is quite peculiar. I've Bell sympatico. When I see the TV connected directly with bell - I see the sub titles, but when connected thru p30-- thru av rear I do not get the sub titles at all. I wanted to record a few shows with subtitltes, but as mentioned I do not get the subtitles at all. Can some one plz. help me with this problem. I was just wondering if I'm doing something wrong or is it the problem with all. I want to record a prog. with subtitltes plz.
Thanks a lot guys. -
good question. and related to that, is it possible to record analog cable tv with the black closed captioning on the bottom and include that closed captioning on the dvd-RW?
I was seeing a lot mentioning abt. the firmware for Daytek P-30. It was mentioned to use the liteon. What I understand from the threads mentioned above that with the new firmware you could set up the disk record time to 3 hrs instead of 2 hrs or 4hrs. Is there any other function/functions which are added to P30 except this?
Daytek P-30 has to be changed to Liteon 5001 to use hacked firmware. It won't do it directly. Follow instructions on this site. At least the Akai DVD-RW 120 will accept the firmware disc for a Liteon with no modifications needed. Handy that!
could you give the link for instructions please-thanks
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
Daytek 950s
By thewitt in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Jan 2009, 11:34 -
Daytek P871 :?:
By jean1938 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Jun 2008, 21:55 -
Daytek firmware
By DereX888 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 10th Feb 2008, 13:32 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 22:22 -
Daytek 2101S
By Newbie_here in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2007, 22:10
