It seems some apps will reconvert that to 720x480 (dvd architect included). So why not just capture at 720 and forgo another conversion where info could be lost?
Is there a way to get a 352x480 reso onto dvd using an authoring app or should I just capture at 720x480 even though this is a waste (for vhs and Hi8) video?
You'll see many arguments on this. I capture at 368x480 and crop to 352 (see the (amazing discovery in capture... thread). I burn 352x480 onto DVDs exclusively. I can get more onto a DVD that way as I can lower the bitrate. Some authoring apps insist on reencoding though. I had one that did that and got rid of it. I use dvdauthor with liquid217's sweet GUI...
The problem is not the resolution. On your case, it's a really crappy authoring program.
A good authorign app should take all, if not most, DVD resolutions and both MPEG formats (allowed in spec, at least).Want my help? Ask here! (not via PM!)
i use 352x480 when i'm burning episodes of tv series, there is a quality sacrifice, but the amount of episodes you can get on a disc makes up for it.. atleast for me.
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 13:08 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 02:24
