Whenever I try to encode anything in Divx in this program, the result is a heavily artifacted video. Has anyone ever experienced this before and/or fixed it?
Please be patient in future. It may take a few days for your answer.
After that, if there is no reply, you may bump your topic if you wish.
This is an informal warning.
Moderator Offline
Don't use Premiere to do it.
Use TMPGEnc to do it....
What ever format your video file is in...say AVI or mpg
exit the wizard in TMPGEnc and go to the option menu > environmental settings > VFAPI Plugin
in that list you should see your DivX codec. If not you need to install it. Once installed....load your video file and then goto File > Output settings > AVI
when the save window comes up you should be able select settings beside your video setting, click the setting button and a box will popup that will let you select your DivX codec.
Now if memory serves me correctly, there are several settings that you can play with in the DivX settings if you decide to adjust them.
I don't think Premiere handles the DivX codec very well, I don't do DivX anymore so I've not tried it with Premiere.
Adobe Premiere Pro CS5.5 CUDA encoding slow??
By Brainiac in forum EditingReplies: 5Last Post: 22nd Oct 2011, 23:35 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 14:16 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 19:27 -
Adobe Premiere Pro 2 Problem
By mymuckaccount in forum Video ConversionReplies: 2Last Post: 20th May 2008, 15:17 -
Adobe Premiere Pro & Burning DivX
By epsilon9090 in forum Authoring (DVD)Replies: 9Last Post: 22nd May 2007, 15:42
