If there a way using fmpeg9commandline) to have it do this:
1) If the file is 48000Hz 16 bit stereo, then it will not do anything to the file except write a new file
2) If any of these properties are not above specs are not present then it will apply the apropriate conversion?
what I am getting at is I would like to be able to compress compliant audio streams, without having to check the file for compliancy first and to not waste time processing something that already is right.
Or will it do this automatically? For example, if I tell it to resample audi to 48000, and it already is 48000, will it skip the process and just write a new file unmodified, or wil it waste processing time reprocessing it into what it already is.
Results 1 to 1 of 1
Missing options in FFMPEG ? ex: cartoon for libxvid .. Please help!
By hugzzz in forum Video ConversionReplies: 1Last Post: 23rd Feb 2012, 13:10 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 06:09 -
Cannot Format Specific Options in MKVmergeGUI
By PikachuCLS in forum EditingReplies: 2Last Post: 14th Apr 2011, 17:41 -
FFmpeg options ? Bad result on a standalone
By Umen Pich in forum Video ConversionReplies: 4Last Post: 18th Jan 2009, 10:28 -
ffmpeg options for PS3 transcoding
By techid in forum LinuxReplies: 6Last Post: 23rd Jun 2007, 04:40
