Why is I-Author so difficult to find? And why does VCDHelp not have a place to point to for it? Is it illegal to be hosting it now or something? If not, what if *I* hosted it? What's so good about it? Why do people speak highly about it, but it's hard to find? Is it not freeware? Where can I get it? What can I-Author do?
It seems that there are many things on this site that talk about SVCD having the ability to do multiple audio tracks as well as multiple, non-embedded subtitles, but yet no one really touches on taking advantage of it as well as explaining a really good method of doing it. Is it REALLY THAT DIFFICULT? And another question: If you make use of selecting a different audio track as well as the use of seleting subtitles, would that shorten the length of SVCD video you can put on the CD? If so, by how big a margin?
An example would be nice.
Thank you in advance.
I hope my bombardment of questions isn't TOO annoying.
I just like to get them out of the way and have them answered in one shot.I find it nicer that way, don't you?
_________________
-= The VidKid =-
www.NSSgamers.com
www.TheVidKid.com
If you want my ICQ#, MSN or Yahoo Messenger ID, just ask.
<font size=-1>[ This Message was edited by: The VidKid on 2001-10-24 04:47:10 ]</font>
http://www.doom9.org/mpg/iauthor_guide.htm
http://www.doom9.org/mpg/subs_and_multiple_audio_tracks.htm
No, I-Author isn't freeware.
If you create a SVCD with several audio tracks/ subtitles, of course the filesize get larger. FitCD helps to calculate the bitrates.
I-Author is not freeware. Hosting it would be hosting WAREZ and this site does not do this.
There are multiple guides showing how to use the I-Author muxer for the multi-soundtrack and OGT (as Truman has posted).
Any of the bitrate calculators will help you determine how much space you loose. Subtitles won't greatly reduce capacity, but another audio track potentially could.
Regards.
Michael Tam
w: Morsels of Evidence -
buy it at http://www.enreach.com
I only dream in black & white...
MSN: paschendale@gmail.com -
no one has blurted out where to get iauthor because that would be frowned upon. it's relatively easy to find if you dont trip over it first. thoroughly investigate this site & others and you might be pleased at what you find
On 2001-10-24 06:35:17, Dhruv wrote:
buy it at www.enreach.com
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Apparently you can't get it outside of China anymore
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
how to author a CD?
By michcio in forum Authoring (VCD/SVCD)Replies: 4Last Post: 2nd Sep 2008, 13:06 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
seems to author twice
By BroomQueen in forum Authoring (DVD)Replies: 7Last Post: 15th Oct 2007, 08:22 -
Help with TMPGEnc Author 3.
By de8212 in forum Authoring (DVD)Replies: 0Last Post: 2nd Aug 2007, 18:27
