Howdy,
I want to make backups of some of my DVDs and have seen two types of prgorams. I've seen ones that will take the entireDVD and compress it down so the entire thing fits onto one DVD, and I've seen some that don't compress it at all and make it take up to 3 or 4 DVDs.
Is there any program that I can choosehow much to compress and how many DVDs to span so I can still get good quality but not have to use more than 2 DVDs.
It should only take 2 DVDs period. Commerical DVDs are either DVD5 (single layer) or DVD9 (dual layer). There are a few double sided DVDs out there so unless you buy double sided blanks (they do make them) you'll have to use multiple discs.
However, each side is either single or dual layer. For backing up single layer discs just use DVD decrypter. For backing up dual layer discs you can either:
1) Spilt to two DVDR discs (no lost in quaility)
2) Compress to fit on a single DVDR (quaility lost but might well be below what your eye can detect)
3) Only backup the main movie (might have to compress but less of a quaility hit)
There are lots of programs that can do option #1. Freeware wise IFOEdit and DVDFab are popular. DVDFab is no longer freeware but previous freeware verisons are stll floating around here and at http://www.doom9.org
Span multiple discs with video?
By kruuth in forum Newbie / General discussionsReplies: 9Last Post: 27th Mar 2011, 09:56 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
Converting discs made on a set top box.
By mtdg in forum DVD RippingReplies: 3Last Post: 20th Sep 2008, 15:51 -
Ritek set to mass produce rewritable BR & HD-DVD Discs
By akrako1 in forum Latest Video NewsReplies: 6Last Post: 24th May 2007, 09:24
